Oggi è mercoledì 20 ottobre 2021, 18:31
Apri un nuovo argomento Rispondi all’argomento  [ 7666 messaggi ]  Vai alla pagina Precedente  1 ... 504, 505, 506, 507, 508, 509, 510 ... 512  Prossimo
 Oggetto del messaggio: Re: Panamericana
MessaggioInviato: mercoledì 8 settembre 2021, 8:13
DwayneD ha scritto:
...Non vedo l'ora di costruire i nuovi kit del 1950 e del 1951 poiché ora sono nella scala corretta e posso apportare queste modifiche come suggerito.
Ciao Dwayne, se ti riferisci al Tron non mi pare che la scala sia stata corretta.
MessaggioInviato: giovedì 9 settembre 2021, 2:43
Hi Marco
When I put the new TRON Oldsmobile bodies next to my old TRON Oldsmobile they looked a different size.
I could be wrong, and as you say they are the same, I will measure them when i can.
Thank you.
MessaggioInviato: giovedì 9 settembre 2021, 5:45
Thanks Dwayne, it seems to me that Angelo Tron told me he hadn't changed the scale, but maybe I'm wrong.
MessaggioInviato: venerdì 10 settembre 2021, 4:28
Good news for us here in Sydney today, we will be coming out of lock-down next week.
That means I can go and get the paint I need to finish the cars I have built ....YAY :D :D :D
MessaggioInviato: venerdì 10 settembre 2021, 4:31
Bene, Dwayne! Ottima cosa!
MessaggioInviato: lunedì 13 settembre 2021, 10:02
Hi Marco.
Well my friend you were right, the new TRON Oldsmobile in the new kit, is the same size as the old TRON kit.
It is funny how the eyes can be deceived, I thought the new kit was to proper scale, I was wrong.
The published dimesions for the 1950 Oldsmobile 88 2-door coupe are 5131mm long and 1910mm wide.
This in 1:43 scale is : 119.32mm long and 44.4mm wide.
The TRON Oldsmobile 88 measures 114mm long and 43mm wide, so it is not long enough but is close in the width.
I don't mind modifying models, but adding 5mm to the TRON car would be difficult, so I will stay with the car as it is.
We have to thank makers like Angelo Tron for giving us these models in the first place, so that we may have the cars in our collections.
MessaggioInviato: mercoledì 15 settembre 2021, 5:44
Saluti a tutti
Some weeks ago I was in contact with our friend Guy Muller.
In our emails we were discussing the Alfa Romeo 1900Ti's from the 1954 race.
Guy mentioned the color of the door panels with the numbers, and how all manufacturers ABC Brianza etc., were the wrong color.
According to the 1954 rules, door panels for the European Stock Class had to be orange panels with dark blue numbers.
I believe that Apostolos with his models of the Alfa is the only one to get the door colors right.
So while discussing the Alfa's we remembered a little car that we hardly see now that was in the 1954 race, the Borgward Isabella #253.
And because this car ran in the European Stock Class as Guy said, it also had to have orange/blue panels.
All of the Borgward's I have seen have had yellow door panels, mine included.......
IMG_3384 (Small).JPG [ 60.43 KiB | Osservato 528 volte ]
So just to share with you the change of door panels I have just done on my little Borgward.....
BORGWARD # 253 (Small).JPG [ 60.04 KiB | Osservato 528 volte ]
I hope this helps those that might have this car in their collection, and thanks to Guy for his help also.
MessaggioInviato: mercoledì 15 settembre 2021, 10:06
Sì, Guy è un amico e sono lieto di questi scambi "culturali" internazionali.
Dwayne, hai fatto bene a correggere la Borgward... così è più corretta!
MessaggioInviato: giovedì 16 settembre 2021, 0:42
Grazie Elio, sono d'accordo che è fantastico che questo Forum abbia un tale scambio culturale, persone interessanti da tutto il mondo.
Sono felice di far parte dell'amicizia che abbiamo.
MessaggioInviato: giovedì 16 settembre 2021, 1:34
Con il tuo permesso, vorrei visitare di nuovo un'auto che ho postato sul Forum qualche tempo fa.....
IMG_4353 (Small).JPG [ 46.18 KiB | Osservato 444 volte ]
Questa è la Oldsmobile della Corsa del 1950, tuttavia il mio amico Apostolos mi ha gentilmente detto che il tipo di Oldsmobile era sbagliato.
Il modello che ho realizzato è l'Oldsmobile 88 e non l'Oldsmobile 98.
Quindi grazie ad Apostolos per il suo aiuto.
Allora sono andato alla ricerca di una Oldsmobile 98 e ho trovato questa macchina fatta da Madison.....
OLDSMOBILE MADISON 98 (Small).JPG [ 51.96 KiB | Osservato 444 volte ]
Ho deciso di lasciare il colore del modello poiché questo colore Maroon era un colore per Oldsmobile nel 1950.
Questa è l'auto dopo l'applicazione del Bare Metal Foil, i ritagli del parafango posteriore e le nuove ruote e l'interno....
OLDSMOBILE 98 FOIL (Small).JPG [ 51.47 KiB | Osservato 444 volte ]
OLDSMOBILE 98 INTERIOR (Small).JPG [ 53.27 KiB | Osservato 444 volte ]
Questa è l'auto finita con nuove decalcomanie per i tuoi commenti.
Grazie ancora ad Apostolos per aver condiviso le foto che mostrano il testo sul tetto......
OLDSMOBILE 4 (Small).JPG [ 53.69 KiB | Osservato 444 volte ]
OLDSMOBILE 1 (Small).JPG [ 54.34 KiB | Osservato 444 volte ]
OLDSMOBILE 2 (Small).JPG [ 54.27 KiB | Osservato 444 volte ]
OLDSMOBILE 3 (Small).JPG [ 56.76 KiB | Osservato 444 volte ]
OLDSMOBILE 5 (Small).JPG [ 58.16 KiB | Osservato 444 volte ]
Your comments always welcome. Thank you.
MessaggioInviato: giovedì 16 settembre 2021, 1:44
E' molto molto bella, questa Olds! Anche Apostolos è un grande... :D
L'unica perplessità, se posso scriverlo, è relativa al colore. Poteva essere questa la tinta esatta, certamente, ma la sicurezza credo non ci sia... o lo stesso Apostolos te l'ha confermato?
MessaggioInviato: giovedì 16 settembre 2021, 2:04
Non andartene ancora.......ne ho un'altra da mostrarti!!
Quindi ora avevo una Oldsmobile 88 blu che era la #91, cosa fare con questa macchina?
Nella foto del 1950 di tutte le auto parcheggiate insieme possiamo vedere la Oldmobile #78 in fondo alla foto, ed è una Oldsmobile 88....
ITEM 8 AND 9 CAR 78 ROOF AND DOOR NUMBERS (Small).JPG [ 66.28 KiB | Osservato 450 volte ]
Ho deciso di lasciare il colore blu scuro, poiché questo era un colore per la Oldsmobile 88 nel 1950.
Quindi ecco l'auto rinata a nuova vita ora come #78.......
OLDSMOBILE 78 1 (Small).JPG [ 51.64 KiB | Osservato 450 volte ]
OLDSMOBILE 78 2 (Small).JPG [ 53.28 KiB | Osservato 450 volte ]
OLDSMOBILE 78 4 (Small).JPG [ 52.34 KiB | Osservato 450 volte ]
So che potrebbero esserci dei commenti sulla parola Venezuela sui parafanghi anteriori.
Gli autisti sono venezuelani, e sotto una lente d'ingrandimento il testo sembra un po' Venezuela.
Come sempre può essere cambiato se appare una nuova foto.
OLDMOBILE 78 5 (Small).JPG [ 51.79 KiB | Osservato 450 volte ]
MessaggioInviato: giovedì 16 settembre 2021, 2:20
Hi Elio thank you.
As always with the colors it is very difficult, and we can only use old color charts found on Google as an example for what the colors could be.
I believe that as long as a color is one that was available on the real car, then perhaps it is permissable to have a good guess.
We can build the cars with a close original color as our hobby, and publish them for members to see.
It is understandable that Valerio for example, cannot do this as his company is a manufacturer, and therfore has to be exact with his models presentation.
We need a "Time Machine" to go back and take photos with our iPhones ha ha !
MessaggioInviato: giovedì 16 settembre 2021, 4:38
>We need a "Time Machine" to go back and take photos with our iPhones ha ha!
Ah ah! E sì, caro Dwayne... sai quanti modelli faremmo? :mrgreen:
MessaggioInviato: giovedì 16 settembre 2021, 5:26
Elio Posso solo immaginare te ed io mentre usciamo dalla nostra "Time Machine" e percorriamo la Panamericana con tutte quelle macchine pazze insieme.
Forse un po' di Tequila in arrivo ha ha ha!
